Scenes should I delete
Papoise
I just got my phone 2 weeks ago and only used one scene I checked that I had a social,play etc scenes with alot of widgets and stuff on the phone. I only use one my custom scene are these other scenes affecting battery life I just noticed these extra scenes and wondering if I should delete because I don't use them.
It shouldn't be causing any problems (minimal space and no battery). Delete if you want, keep if you want... totally up to you.
Yeah, from my experience if you have stuff setup on one of the scenes it only loads up when you used that scene. So if you don't use facebook and twitter much, leave them on the social scene and while on another scene you won't need the app running in the background. I set up a couple scenes this way for mail and messaging as well as social stuff also.
