The link to the superuser files seems to be broken. Is there another place to get the files?
& thanks in advance! You're truly awesome, Scotty
just to make sure, I am putting the Superuser-3.0.7-efgh-signed.zip file into sdcard2, correct?
This is where I'm getting kinda confused because... I'm still not sure which directory is the phone's "real" root folder. Before, I thought it was the /mnt/sdcard :'(
Any clarification would be appreciated& thanks in advance! You're truly awesome, Scotty
edit: Just more clarification. I was able to get root access (according to all the root-only apps + that root checker app). So now all I want to do is do a nandroid backup (via Amon Ra - followed this guide to a T via the TEMP Recovery method) but for some reason I can't go into the Recovery mode. I'm getting the hboot screen, just that I get stuck/hung up on the screen with that red exclamation point. So... I'm starting the process from step 2). Figured it could be me putting that Superuser-3.0.7-efgh-signed.zip in the wrong place/folder.
)remember,you did not permanently write a recovery,so when you select "recovery" from the hboot menu,it is taking you to the stock recovery,wich is the ! triangle screen.
you will need to go to fastboot (not hboot) and fastboot boot <recoveryname>.img every time you want to use recovery. its a couple extra steps from a booting to a permanent recovery,but is a good habit to get into IMO,as launching recovery in this manner will let you restore backups without a seperate kernel flash.
hope that helps clear it up
last and not least...
a neat trick for keeping track of your sd card,is to figure out which it is(put it in a card reader is a surefire way) ans create a folder named "aaa SD card" or somethin to that affect... it should always be the first folder on your sd card,and make it pretty obvious that youre in the right place(thanks iowabowtech for that tip)
Any ideas of what went wrong? I also have not been able to find a stock recovery to try to flash it to the phone.
Thanks for the quick reply Scotty. I was thinking that the stock recovery had some sort of UI and that i would be able to tell that its there. Don't think i every looked at it before i was rooted.
htcdev,while it has limitations,does allow alot of user error,as the bootloader and radio are protected from accidental,or intentional flashing. its more or less imposible to "brick" a S-ON rezound with beyond repair,with software flashing since only boot,system,and recovery are accssible via htcdev unlocked s on hboot
Scotty,
This is definitely good info, and I clicked the thankyou button, but ... I don't think it's very noob-friendly. There's some important details left out at the end, details a noob wouldn't understand.
I did manage to figure it out, but ... What if I re-formatted / edited your post to make it more readable / easier to follow, and included a link to your original post? Would that be cool? It's good info, but I think it can be made truly noob friendly with just a little help ...
Yes, I did try everything in post #68... did not fix the problem. Verizon is sending me new sim card, but I don't think this will fix the problem. Any other suggestions? I've read that I should NOT do a factory reboot as this may brick my device... is that correct?did you try the things listed in post #68 to get your data to come back? it is peculiar that you are the second person to have this issue,now.
Hey, the Amon Ra recovery img isn't mounting on my computer after I download it. I'm on an iMac.
Had my rezound for about 5 days now, and I want to remove the bloatware just to make it faster and improve on battery performance, thats all.
