screen brightness & extended battery none root s3
mailroomman
Hi guys
A quick ish question for you .
I have just recived a 4600 mah extended battery and back cover .
Now i want say from the start of this thread i dont want to go down the root road as i im happy with the way my s3 is in a stock perspective .
The battery is epic for my needs and it just keeps going and going and going you get the drift it last ages more than the stock battery.
But when i get to 5% mark the screen dims down and i understand the phone is just trying to stay alive and the battery level gets to 2 %
And thats it no more movement or warnings fine i can live with most of it but what does anoy is the screen dimming .
I want it at level i wish not at life support level.
Is threre a way to trick the phone or do somthing to get around this without rooting .
Any ideas ill happily try out .
Thanks all
Mailtoomman
No not a power saver but i do have long battery life app running .
I have just finnished speaking to a friend and looks like i may have to root
But thanks
My S3 is in Auto Bright mode
But when I open it outdoors its dim
& then I have to rub the screen like a Genie :p
for it to get bright, did not have to do that in my Note or S2 :(
is there anyway it remains bright when i open to view my phone
I have it set on Dynamic
& i too dont wish to Root my phone
Thanks
My S3 is in Auto & when I open it outdoors
its dim & then I have to rub the screen like a Genie
is there anyway it remains bright when i view my phone
& i have it set on Dynamic
Thanks
frankly i think the auto brightness on our phones is just plain awful...and hopefully Samsung is aware of it and they have a way to fix it...i think the phone is WAY too slow to react to bright conditions...and is just plain poor at reacting light levels in general...
whenever i have mine set to auto brightness the phone is almost always on its dimmest setting and it drives me nuts...honestly..i have the screen on max brightness all the time unless im using it late at night...then ill just click auto adjust on...
