When you are recharging the Galaxy S2 from empty, is it normal to have what look like green horizontal lines across the bottom half of the screen (the screen is otherwise black)??!?!
I unfortunately forgot to charge it last night and it ran down, so plugged it in when I got home and that is what I see. When I plug it in it vibrates, I assume to indicate that it is in fact charging, but the screen itself is black apart from those lines... they appear when I press the power button and then sort of fade back to black. I can't view the main screen or anything.
I should mention that I've never flashed it or rooted it or anything.
I don't have another battery to try out either.
