My HTC EVO 4G dims to the lowest brightness setting on it's own randomly without my touching any settings. It is happening regularly and often. This started happening within last 48 hours without downloading any new apps or updating any system updates.
I am up to date on my firmware, profile, PRL and HTC software as of March 7, 2012. I thought maybe it was the QUICK SETTING app I installed (which worked fine for last 18 months) - so I uninstalled it and it is still dimming to the lowest setting by itself.
Few quirks I noticed: When the screen dims and I click the QUICK SETTING app to raise the setting, (very often) the screen goes back up to the brighter setting, although not 100% of the time. Once in the settings screen, I can see that the brightness scroll bar has been drawn down the its lowest setting.
I tried resetting it with and without the AUTO BRIGHTNESS - no help. I tried the SCREEN TIMEOUT at various settings - no help. I have tried setting various things with the phone's original SETTINGS menu - no help. I took the battery out for 60 seconds and tried - no help.
One thing I have not yet tried is factory reset which I do not want to do, if at all possible.
Any ideas?
Any ideas?
