Screen Filter...
GNS1310
Doesn't turn off the soft lights? Since when?!? Just bought a dock and have a full screen dock-mode clock that I run, but the soft lights won't shut off!
Jeez when I want them on, they're off, when I want them off they're on!
Anything else out there that will do the trick?
Seems like something about the dock is keeping them active? The lights respond to ambient brightness -- they turn on when you use your phone in low-light situations.
The brightness of the lights can be set / disabled by a few apps HOWEVER YOUR PHONE MUST BE ROOTED IN ORDER TO USE THE APPS.
https://play.google.com/store/apps/...htness&feature=nav_result#?t=W251bGwsMSwyLDNd
