Help Screen Freezing
thomeboy
I am having a really weird and frustrating problem with my htc hero. It started as something that would only happen every once in awhile but now is doing 100% of the time. At first it seemed to only happen if I had my phone in my pocket for a long time like when I'm at work. When I checked my phone hours later my phone would not do anything, it was stuck on the lock screen and was not responding to me trying to unlock it. I hit the end button twice and then it comes back to the home screen. If I then tell it to slide to the left page it won't respond but if i hit end twice it will show the next screen. Sometimes though it will be on one screen and I will see another.
My phone is not usable like this I can't get to any settings. It seems like the phone is recognizing what I'm doing but not updating the screen. The screen only updates (50% of the time) when I press end and then end again.
Please help!
It sounds like your touchscreen may be going. I believe you can take it to a Sprint store and get it checked out for $35.00 if you are still within the first year of ownership.
If you can get into HBOOT, you may be able to perform a factory reset. That might clear up your problems. Follow this guide here to perform the factory reset: How to hard reset the HTC Hero - Know Your Cell .
