mzelsmannjr
My screen goes black during phone calls, usually within a few seconds. This is especially annoying when connecting to voicemail. I thought I saw an app for that but now I can't find it. Or is it a setting I can't find?
If you aren't blocking the proximity sensor, then you can use the app called screebl lite to keep your phone screen on while holding the phone.
You can't adjust the proximity sensor, just the screen backlight timeout setting. Just make sure you aren't holding the phone in such a way as to block the proximity sensor in the upper right corner of the phone (near the LED).
mine always goes black but as soon as you remove the phone from you face, your screen will come back. Sometimes I have to shake my phone to wake it up and show my screen.
The phone does this automatically when your face is covering the sensor. If you're having it stay black when your face is away from the phone then you might have something you can get covered under warranty. Have you pressed the power button if it is black when your phone is away from your face
