Help Screen Goes Dim in Bright Light
Benrx
I searched for other posts on this, but didn't see one.
When I unlock my phone, the screen brightness will be high, and then it adjusts to correspond to whatever the room brightness is. When I am in bright light outside, it will go dim a few seconds after getting unlocked. Its really frustrating. I can't see the screen.
I have the screen brightness set to automatic. Is there something else I need to change?
Thanks,
Ben
Yea... change the setting from automatic to something else.
Thanks for being unhelpful. If I manually adjust the screen, then it will be too dim when I'm outside and too bright when I'm inside. I'll constantly be fooling with it. The point is, it should work correctly to begin with.
You're welcome.... Proof is in the pudding. You leave it on auto, it changes on it's own. Set it yourself it stays.
My solution was to use a brightness toggle on my homescreen.. fast switching.
