Screen Issue
barnacles
So I just installed a ZAGG protector on my phone, waiting about 20 minutes after installing (figured this would be enough time since when I had it installed at bestbuy once they turned it on right away) powered on my phone and the screen is going crazy. It is not registering swipes first of all. Second its running like i keep clicking things. The search bar will come down, then go away, it will flick left, then right, then left, it even changed the wallpaper. It started messing with some of my widgets too, clicking them down as if they were being moved and then releasing right away. This is all with me not doing anything at all. Any idea what this could be?
Phhhew. Alright, so its been about 40 mins since I installed it. Had it turned off with my fingers crossed. Just booted it back up and it seems to be working a bit better.. maybe it was just the moisture under the protector as doom mentioned.. idk hopefully it continues to get better..
