Help Screen issues
creator69
In the last few days my screen starting becoming non-responsive after a lot of use. Other times when it starts acting up the screen will turn itself on and acting all sporadic. Anyone else with these issues?
Seems like it is doing all the time now. turn on screen and it is jumping all over and I can't select anything
Do you have a lot of applications installed? The problem might be caused by a rogue, or incompatible app.
Find the culprit ...solve the problem. Start by uninstalling the largest(gb) to the smallest(kb-mb).
Post back if you're still experiencing any problems. ;)
I started by removing the google experience launcher, and I'm wondering if it is an issue. They recently made an update to google search. So I went back to lg launcher to see if it is any better with that
If the above advice doesn't work out for you, it's a safe bet your digitizer is starting to go out with the ghost touches. My retired Evo 3D started doing the exact same thing. Only fix was getting the digitizer replaced.
There's nothing in particular that can cause this, as for mine it just randomly started going bad. My guess was just faulty hardware.
If you decide to get the digitizer replaced (without insurance), it's going to cost a pretty penny.
If I'm not mistaken, the lcd and digitizer are in one. When I shattered my screen, it cost me $186 to have the lcd and digitizer replaced (professionally done).
Is it still possible to back up my phone if I hook it to computer if I can't select anything on my phone so I can transfer files I have a replacement coming?
