Does it turn on while just sitting on a desk or table? Mine was having similar problems. I would turn off the phone by knock knock, then lets say i was going to lay it on a table and if my finger was touching the screen as i lay it on the table then it would turn in sometimes. I turned off the knock knock feature and the problem went away. I think it is a bug with the sensor or something.
I like knock knock a lot to. Are you sure it is not turning on because you have incoming notifications? My phone turns on when i receive text messages.
Can you still return it? Are you using a custom rom or stock?
settings>gestures> motion sensor calibration
try that... mine was doing the same thing until I calibrated..... the phone was picking up minor vibrations while driving and turning on thinking I was tapping on it
