Help Screen Light Up Upon Receiving Text?
msuey
I've seen this question asked for other phones, but I'm not sure if the interface/settings are different for the Note 2 so here we go:
Anyone know how I can get the screen to light up when I receive a text?
I understand that it saves power for it not to, and there is an indicator light, but I wear headphones a lot, and I depend on the whole screen lighting up otherwise I will definitely miss the text.
mine always does and wish it didn't as its a waste of battery for me.
Hi
Well, mine screen does light up for about a second when I receive a text using messaging, but if I change to using Hangouts for messages it doesn't. If I untick notifications in the notification settings in the messaging app, then it does not light up on receipt, but of course the led does not flash either (and no sound/vibration)
msuey, Rhuematoid, you dont say what models of phone you have, I wonder if the lighting up is particular to international GT-N7100 and different on some US models?
Just found an answer - see post #8 and #9 in this thread http://androidforums.com/samsung-ga...creen-comes-all-time-itself-every-min-so.html
Hope this helps
Roger
Hi
Yes, I think that probably helped stop it, but I suspect if it does not happen its a "feature" of your ROM Which carrier/phone version do you have?
Roger
I thought the screen lighting up for incoming text was normal. I remember many of us using an app to make it stop.
By any chance do you have power saver enabled?
Hi, it used to light up when I received a text and then when I updated the software it quit doing it. :(
Power-saving is off.
