Help Screen lock during the call?
Skang
Hello, i am new here.:)
So, i was trying to make a payment over the #pmt.
but, whenever i try to press key button, screen will just black out every 2 sec, i had to press volume button everything. really pissed me off. :mad:
how do you guys punch Credit Card number like that?:confused:
go to settings> sound and display> screen timeout.
default i think is 1 minute, so check to see that its not on something low like 15 seconds.
next, do you happen to have "Fast Reboot" installed on your phone?
i dont have any of those. pretty much stock.
maybe i was in the room? room light was on at dark night.
I have the same problem, although it happens every time i try to hang the phone up as well. I will take the phone away from my ear and it locks up, so i unlock it and then the screen will shut off. so then i have to turn the screen back on, and then i am able to press "end call". I pretty much have factory apps for the most part, so unless the Fast Reboot comes installed on the phone, i don't have it. i know that my finger is not covering the sensor and it happens everytime, no matter what lighting i am in...
Can use all the help i can get!!!! it is driving me crazy!!!!!!:mad:
I recently noticed this as well....attributed it to being root-ed with a 3rd party ROM/kernel but it looks like thats not the cause of the issue.
I noticed that turning the phone off and back on again fixes it, at least for some random amount of time.
I did have fast reboot installed at one point but Ive since wiped the phone and started with a different ROM and kernel, without reinstalling fast reboot and the problem still occurred again.
Im wondering if its a bug with the stock set, which the 3rd party ROM/kernel Im using is based on
i found this in a different thread posted by namelee78
it worked for me!!!!!:D
Hello Galaxy Lovers!
I solved the problem that screen goes black even if your phone is away from your chin and I'm sure it will also help you to get rid of unlock during calls.
In my case, one of my apps called System Pannel was killing important service. It is called com.samsung.phoneinfo
This was causing the problems. Of course, I tested more than 50 times by killing this service and make phone calls. In this situation, my solution was put this service on exclude mode and it works.
I know there's thousands apps for managing active apps and services .(Task killers, Advanced task killers...etc).
Please make sure your utility apps doesn't kill com.samsung.phoneinfo.
Here's how you do.
1. You have to battery pull. Turn off your phone, Take your battery out, Put it back and turn your phone on.
2. Go to your apps that kills inactive apps and find com.samsung.phoneinfo. make it this in your exclude lists.
3. Turn off your phone and turn it on
4. Test it. (I called 611 because i don't get charged:))
**** I know it works because, my 4 Friends who has Fascinate tried and got their Fascinate working and they are happy. Please if this solution helps you, reply on this thread so that we can help other people*******
Good Luck guys.
P.S.
Personally, I do not recommend using ATK. Sometimes, it will kill so much apps that phone needs it. You can managed this with system panel apps that I'm using. It is better, because you can manually kills your app when you feel like your phone is slowing down. Also, Smart phone is different than iphone. you have to manage this phone continuously.
I use System Pannel lite to kill apps like Active apps, Background Apps and Inactive Apps with one touch key. Of course, few apps or service, you have to move it to your exclude list so it won't get killed.
I also use apps called Memory booster once a day and quick app clean cache once a day. Then finish with HistoryEraser once a day.
If you would like to feel little bit faster, download Spar Parts and Change your Window animations and Transition Animations Normal to FAST. It will help too.
Thank you for reading and I look forward to hearing from you guys.
Thanks!!!
