Root Screen Lock Feature Removed by Moto?
tp2635
Due to a audio issue VZ had me reset my X, a pain for sure. The phone worked but I couldnt figure out how to turn-off the irritated screen lock as it was before the reset. I think I've found the answer on the Moto website it says "
<LI style="mso-list: l0 level1 lfo1; tab-stops: list .5in; mso-margin-top-alt: auto; mso-margin-bottom-alt: auto" class=MsoNormal>If your DROID X handset had "simple swipe screen lock" turned off and you upgraded your handset to 2.3.15 Froyo update, you will not have the option in settings to turn it back on again because the ability to turn that feature on / off was removed.Can this be the only answer? The just decided to remove a feature like that?
Does anyone know of a way to turn of the screen lock?
try this
No Lock
by BoD
50,000 downloads, 3098 ratings (4.3 avg)
Free
