bluesmartie
Hi. I've had to start using the screen lock, as when I don't the phone manages to slide the screen, in my pocket, and selects all manner of things. Something I've tried recreate on purpose, but can't, very infuriating. As annoying as I find having to type a pin, this solved the unlocking in my pocket issue. I've also changed the time-out delay to 30mins, so I lock and unlock the phone when I wish. The problem I now have, is when I make a call, the screen begins to dim immediately, then it goes blank. I then have to push the home key and input the pin to hang up. Or, when the caller hangs up the screen lock appears and I have to input the pin to continue using my phone. This is regardless of whether the screen lock is on prior to the call or not, or if I'm making the call or receiving. My proximity detector is turned off, the screen is dimming regardless of proximity to anything and not in line with the 30min time-out I've set. It's not the worst issue, but it's very annoying, I'd like to just be able to use my phone when I like, without having to put a pin in after every call. All help is appreciated
