Apologies if there is an answer to this elsewhere, I can't find it, feel free to direct me to the right place....
Having dropped my S3 flat on its screen, the screen no longer works. When turned on the back and menu buttons light up but no action on the screen. I was hoping that the digitizer flex cable had just come loose, so I opened her up but it was fine.
Would it be safe to assume the digitizer is screwed and the only way forward is to replace?
Thanks in advance for any help.
If something goes wonky, then sub out the repair
