Help Screen problems
Changing screen messed up my HTC EVO 4g screen Resolution?
I had problems with my HTC EVO 4g screen responding to touch and took it to sprint store. They changed the screen and that problem was fixed. However it came with a resolution problem. The resolution seems to be lacking colors or something it doesnt show clear pictures any more. it seems like when u have only 24 colors on a pc screen. How can I correct this without going back to the store? I wanna avoid that if possible since i really need my phone to be working on weekdays
Thanks alot
there really is no way to fix it other than go back to the store and have them fix it correctly. They either used a bad screen, or didn't put it together correctly.
