So i'm having a problem with my screen, it's very sensitive. I keep touching things on accident that i don't want to touch. Is anyone else having this problem too, or is it only me?
I'm pretty used to it now.
Interesting, glad you found this tip out. It works perfectly like that. I shure hope some one fixes this isue though, but until then its two fingerd at a time. Great find!I found something interesting that makes me think it may not be a hardware problem. If you try to drag with two fingers on the screen, it works pretty much like you would expect it to. Try holding an icon on the home screen, touching somewhere else, then dragging. Works just fine. Same is true in games with screen controls.
Is it really that bothersome to you guys? I learned to live with it, and I play emulators just fine.
Either by using the on screen controls (works just fine for me) or using the physical keyboard.How?
It's hard to play Sentinel3 Home world!!!!Either by using the on screen controls (works just fine for me) or using the physical keyboard.
