M
Member12446
Guest
Anyone tried any of the myriad of screen protectors out there? Any recommendations? I'd usually go for a Zagg but they don't do them yet. TIA.
Good to know. I have been a little wary of the big brands of 'complete case protectors' because most of them are known to 'enhance grip', which is fine for the case but not exactly what we want on the screen!Since the screen is tempered glass, having a screen protector isn't critical. However, AT&T sells a matte (anti-glare) screen protector for the iPhone. Pack of three is $15. They reduce glare, make skin oil less visible, and allow your finger to slide across the touchscreen much more easily.
Here's a tip used by hard-core pc modders (when putting windows into their hard drivesJust be aware that when peeling back the protective coating, a static charge is generated. Any dust or lint in the air will be sucked onto your screen protector, so do it in a very clean place or under a de-ionizing fan.
): Go take a shower!
Afterwards, when the bathroom is nice and steamy, you have the perfect dust-free environment. Don't worry, the moisture in the air won't hurt your device (unless you keep it like that for very long time).Zagg just sent me an email and they do offer them now, I dont like the full protection tho its just front and back sides are missing....
I got that mail from Zagg too. I'm considering which to get - do you think the full body would work over the bumpy back of the galaxy??
I've asked zagg about how 'slippery' the screen protector is --because I've read in a lot of reviews that it provides very nice grip, which is fine for the back but rather bad for the display-- and they said "they wouldn't exactly call it slippery".
Please, get back to us about how nice it is for finger sliding movements etc. compared to just the glass surface. Thanks!
