Does anyone out there have a suggestion for a screen protector for the Rezound? I don't want to waste time and money on the bad ones. I got really lucky on the screen protector for my Incredible.
The name brands are similar, though some have their own preferences. I've always used Best Skins Ever. Probably a little more visible than some,but I love the feel and cost.
Free shipping when you order 3 sets. From about 7 bucks for a screen protector or $9 for a full cover.
HTC Rezound Skin
Do you use the full phone skin or just the screen part?
I just use the screen protector part, then I have the seidio case, so it's got all around coverage.
The cool part is that if you get 3 you can screw up the first one practicing and still have 2 more for less than paying to have one installed
I used a Zagg on my Incredible for 20 months. It's a better screen protector, but it does have its down side. The rubbery texture takes away from the quality of the display and can sometimes be sticky with sliding the finger.
So I wanted to try something different, got the Seidio. I dislike it. For one, it's a dry application and so it makes repositioning it difficult. Also, it doesn't cover the ENTIRE glass front side, as in edge to edge like the Zagg. I didn't know this when I went to apply mine and started all the way to one side and wound up with a huge gap on the other side. When I took it off to reposition it, is when I got specs of dust underneath it.
The difference between the two is readily apparent here. The Zagg just conforms around the particle and you never know it's there. The Seidio leaves a huge bubble around that one spec.
v2can5-How's about changing the title of this thread to allude to the screen protector topic instead of putting your user name in it?
^ oh. You have free install too?
(Yeah they do that all day at the store.)
Yes, you use a soap water solution on the skin. I think it's similar to the ghost armor types. I will admit there's a texture to the skin, not smooth like the Verizon ones that just lay on top.Do you have to put liquid or solution on the screen to apply the protector?
This is my first post. How do I change the title?
hit edit on your first post, then hit advanced. you will see the option to change title at top...
btw, i changed it already but feel free to change it to something else
Hal1,
Thanks for the video. It was helpful.
I ordered a Boxwave clear and will report once it gets here. I too like Steinheil but they ain't doing one for this device.
Tried an antiglare with my iPad and when I complained about the quality of the anti-glare shield (they didn't want to take it back despite their 'guarantee') they sent me a uncut clear shield (which I thought was for the ipad). Only tried them again because you don't have alot of choices with the Rezound these days and it was dry application. I've got a Halo shield coming and if that doesn't work I'll get a ghost shield. I'm leary of the wet application because, if you notice, there is a small gap around the glass when moisture can seep downward.I used a Zagg on my Incredible for 20 months. It's a better screen protector, but it does have its down side. The rubbery texture takes away from the quality of the display and can sometimes be sticky with sliding the finger.
