ArmageddonX
Android Expert
Does anyone have any Screen Protector advice?
I was looking at ZAGG because I used that on my phone.
Thanks.
~ ArmyX
Thanks.
~ ArmyX
As for now, I'm ashamed to say I haven't taken off the factory screen protector. I still have that little tab hanging off on the top right corner. I won't remove it until I find something better to replace it with.
LOL! Me too! I still have it on there. My Wife keeps making fun of me lol![]()
I think I am going to order the Zagg one today. I don't like doing it myself so I take them to a local retailer who installs them for $6. The worst part is you have to wait to use the device lol
~ ArmyX
I put the skinomi on a few minutes ago. Watched the video on their web site and it took all of 5 minutes to do it. it is a wet install so they recommend you let it dry for 12 to 24 hours. I will let it lay until tomorrow after work and break out the Fire in the mean time.
I have had smartphones, Tablets and eBook readers for quite some time now. I never used a protector and never scratched or did any damage to a screen. And my method of cleaning was rubbing it glass over my sleeve.
This was given to me as a gift so I will give it a try. If it effects the sensitivity or looks bad, it is coming off
I will let you know in a few days how I like it.
.... I can put one on in about 5 min. after they cure for a few days (if there are any tiny bubbles left they usually disappear) you wont even know you have it on there. It does take a bit of practice to get them perfect. Just dont over squeegy them, and make sure the top has some solution on it so you can squeeg with lube.I'm extremely careful with my devices as well but i have always put a protector on them. In my experience Zagg tends to feel plasticy ... I use BSE(Best Skins ever) they are a wet install skin but take it from me they are pretty damn easy.... I can put one on in about 5 min. after they cure for a few days (if there are any tiny bubbles left they usually disappear) you wont even know you have it on there. It does take a bit of practice to get them perfect. Just dont over squeegy them, and make sure the top has some solution on it so you can squeeg with lube.
Phone Skins | Screen Protectors | iPhone & iPad Skins | Best Skins Ever
