Screen Protectors
Right now, I'm using the AT&T screen protectors, which work great and all, but get really greasy when i even sweat the slightest. I'm usually not the type to worry and don't get me wrong, those screen protectors work great and were easy to install, but I recently read an article about the unlock patterns have been found out due to finger residue.
Ultimately, I'm looking for a matte screen protectors for my Captivate. If I could get a link to somewhere online I could get a GOOD matte screen protectors or one that is highly recommended it would be much appreciated. Thanks guys!
if i get the phantom skinz screen-only kit, will it be matte though? or do i need the full body matte kit in order to get a matte screen protector?
I have used the Invisible shield" Brand @ zagg.com
And the Clear Protector" Brand @ clearprotector.com
If you look online you can find 30-50% off either one of the sites , usually either or , check slickdeals.net or even google.
Both of these worked very good in my experience. Just make sure to put it on right with no bubbles the first time.They will last about 2 years. And when you take them off your screen looks just as good as the day you put it on. They also help cut down on finger prints, but do add a little "orange peel " effect.
