Help screen rare problem!!
fidiasi
My screen has something like oil through half of it and it becomes bigger day by day!!
Anyone knows what could be the problem??
UPDATED PHOTO
I'll take your word for it that there is something wrong with your phone, but the photograph could easily just be a very bad photograph of a perfectly good phone as far as I can tell.
I can't say for sure but I am guessing that the outer screen is separating from the digitizer and what you are seeing is either moisture or possible an adhesive of some type between the two. You should return it under warranty ASAP because it's not going to get any better. :(
I second what "AeolianReflex" said.
This looks like the adhesive is giving way. This can be simple case of bad assembly, or screen exposed to unusual heat. Left in the car or on the table on a hot day.
It only takes simple hairdryer to soften the adhesive and separate digitizer from the glass, so car heat or direct sunlight is more than sufficient to do this to a phone.
If you still have a warranty, I would go ahead and claim it. It's not likely something you can fix yourself.
