Help Screen rotation problems
When changing between portrait and landscape the display does note fit the screen and I have to pinch in for image to fit the screen. Have done a reset. Any help gratefully received.
Thanks
hi,
need more info.
are you rooted?
3G or wifi?
what app(s) does this occur in?
have you removed any apps or added anything prior to this happening?
when did this issue start? ever since you had the tablet or recently?
Thanks for quick reply
Don't know what rooting means, sorry
XOOM is wifi. Only happens in browser. It used to fit the screen when I changed from
Landscape to portrait but now have to pinch the screen to get it to
fit.
Did a factory reset, still no good.
Any help would be great
