Turn off smart rotation. Just realized that is your problem, bring down the notification panel with 2 fingers, press and hold Smart Stay and un check smart rotation
Settings-more-about device keep tapping build number till you unlock developer options, press back and go into dev options and set transition animation to .5
Did not know this. Awesome.
Similar issue I'm having, well not really 'issue' per se: When viewing photos, my GS2 used to auto rotate when I turned the screen around but now you have to press a rotate button. Is there a way to disable this button so it auto-rotates images?
Not sure i completely understand, when the screen rotation is enabled it'll auto rotate. If its not that its probably the smart rotation i mentioned in my last post, and if its not that im not sure what it is, but I'll keep an eye out for other settings
An image will help:
See the Rotate button top right? It's the only way to rotate photos when you turn the screen around. It's greyed out in the image, but if I turn the phone portrait, the photo stays as is but the rotate button becomes available, rather than just auto-rotating as you'd expect. Like I said not an issue per se, but it's an extra button to do something that used to be automatic.
Im on the Sprint Galaxy S4 and i dont even have that option when in a photo, so im not sure whats up with that, sorry
