Not with any built-in setting, it's either turned on or off via Menu, Settings, Display. There may be an app to control it or use a different launcher program that may do it. I like the way it rotates and it doesn't get in the way for me.i did a quick search but i couldnt find any answers, so i was wondering if there Is anyway of stopping the screen from rotating both ways?
I only want it to rotate one way, like it used to on 2.1
It's ok, you'll get used to it. I remember the first time I bought an iPhone and I didn't like it turning at first, but that soon changed.ok guys cheers for the replies. looks like i'm stuck with it then =[
