I have a problem with this phone, and in fact I had the same problem with my S10e. Some sites simply don't scale properly, as you can see by the screen shot below. And of course the most pertinent info, in this case the flight times, are the ones that are compromised. Turning it sideways doesn't help. Was traveling with a buddy with an iphone, a much smaller screen than mine, and his displayed perfectly. This particular case is the Allegiant app, if that's not obvious, but I see it with other sites. For instance, on a log in screen, the field to type in the un or pw is so narrow that you have to type blind and hope. Can anyone tell me what I'm missing here? Thanks!
