chevanlol360
Android Expert
So hey guys I just got off the phone with a samsung rep and I was talking to him about how the screen can be so sensitive and annoying and he had transform ultra pretty close to him so he got and and I was telling him about how it difficult to move apps around the screen and he tried it too and it said yeah there a little bit of a problem with the senitiviy and he said that he would make a note of it and hopefully it will transfered to the upper samsung update center for then to realize and say " hey the screen has a little bit of a problem let's do a update to fix it" and I really do hope that they do a update soon to fix it but for the mean while here's a quick/temp fix for the problem when moving a app put 2 fingers on the screen and it actually worked and he did it too on the ultra that he had in his hand and he said he deff will be sending out a note to the update center he also said that 3rd party apps in the market could temp fix the problems too.
HERE'S ONE
Its called sgs touch screen booster when you download the app set everything to zero and exit the app and tell me if you don't see a big difference it actually workings try moving an app to test it out to see if it worked for you
cuz it does for me thank good for google making the android OS open to 3rd partys app for doing stuff like this
HERE'S ONE
