i've had the x10 mini pro for a few months now and in the past few days the screen randomly will shift when im using it. An amount of the top of the display will instead appear at the bottom of the screen (everything is a centre metre or so higher than it should be). Its been happening a couple of times a day and i've only been able to fix by turning off and restarting the phone.
If anyone has the same problem or any ideas, thanks
