Help Screen Timeout
Hello All
I have had my Wildfire for a few months and am very happy.
Have an issue, my screen does not timeout. I have checked the setting under Screen timeout and is set for 15 seconds but still does not timeout!
Are ther any applications which stop this function working?
Any ideas?
Thanks
Vim
That is my point, I have installed several app but am not aware of any that cause the timeout not to function!
How can I uplaod a list of apps so I can get some help? Do I need to manually ty them in?
Thanks
Vim
Danfrance
I have SystemPanel Lite v1.0.6 installed
Active apps are Battery Indicator, Messages, People, Settings, Touch Input, Weather
Any ideas?
Thanks Again
Can't see any reason those apps would keep the screen alive. Has this issue always existed?
It may be worth removing the apps to see if it is still the case. if so, unfortunately, maybe a factory reset?
