Hi.
My DHD suddently began to light up the display when I didnt use the phone. It annoyed me alot, so i factory reset the phone (2 times actually), but it didnt help.
I think it has something to do with the car panel. Because right after the factory reset, the car panel would come up very often. Yes, very annoying in the middle of an sms and other stuff. So I have turned the car panel off, but then the screen (instead?) just lights up.
No apps are installed.
Hope you can help!
Kind regards,
Lars
Hope you can help!
Kind regards,
Lars
