Help Screen was vibrate when touch
queencode
I was buy samsung note 10.1 2014 edition with white colour. Its nice and i like it overall.
But one which make me dislike. When I touch the screen on one point and several time (start 5 sec), the screen will vibrate (you can try and see the scroll bar on right that if try on setting app). I have try on all aplication (settings, game, contact, message, etc) but same occured.
Anyone could tell me, is it a bug? because I try on another machine on shop, its same too.
@Rockets:
I'm so sorry for this misunderstanding...
The first, I will tell that I have buy a "samsung note 10.1 2014 white 32gb".
Overall, I like this machine and the feature that build it.
But one thing that I dislike after i try is when I touch the screen for a several time (ex: 10 second), the the lcd/image/screen will be sway. This case highly visible when play a game or some application. For example when open settings application and click device (have a long content, can shifted to bottom), when on device touch the screen with hand and see scrollbar on right side will be show and invisible. This conclude that the screen will be sway when touch for several time.
Anyone can tell me. It is a bug? Or my mistake? :confused: :confused:
Nb: I have try on another shop for same machine, but have same case and same problem.
I think you mean what is called haptic feedback. This uses the vibrate feature to vibrate the tablet so you get some feedback so you know when the tablet has registered a touch.
It can be turned off very easily if you don't like it.
[Edit]
Having re-read your posts, I'm not sure whether you mean the image on the screen moves. Do you mean the whole tablet vibrates or the image on the screen moves? If you mean the image moves, mine doesn't do that.
I appreciate that English is not your first language, but your post is quite hard to understand. Can you post a video showing what you mean?
- At homescreen/appdrawer. Touch on any app icon, hold it and it will shaking all the time. Also within 10-30 sec it will drop by itself.
- In webbrowser (any), holding finger on the screen or scroll, the screen shaking all the time until release and i I really hates when the screen shakes. Making scrolling websites real annoying.
Understand? and please advice
Tried it over lunch, mine does not do that if you mean the screen gets shaky and the "picture" looks shaky.
1. Do you have it in a case, if you do take it out and see if it fixes the problem, magnets in cases made my screen do odd things.
2. Have you turned it fully off and back on by holding down on the power button for about 10 seconds then hitting the screen where is says "shut down" or "turn off"?
3. If that does not help you might wipe the system cache.
PS: Where are you from may I ask?
I think I understand but this is not normal behaviour. I have just opened Chrome and held my thumb on the screen. Nothing happened. The display is completely steady with no movement at all.
Something is definitely wrong with your Note 10.1. Without seeing exactly what is happening it is hard to know what the problem is but this is not a feature. It is very strange that another Note did the same thing, which is why I would like to see a video of what you are describing.
I have a same problem with this men and have a answer that this is a bug.
Touch screens issues on Galaxy Note 10.1 (2014) - Android Forums at AndroidCentral.com
