Root Screenshots, themes and customizing
whay launcher and theme is that
Holo launcher, the theme is my own as Holo doesn't like the theme I wanted. With BobClockD3 and HD Widget for weather. The icons come from Platinum Icon pack but had to change them myself as the Icon pack isn't supported by Holo.
This is my tablet and not my phone but i'm in the middle of rethemeing it and this just looks too badass not to show people :P
Stock rom ,fully deodex, modified by me ... can't ask for more !
And last but not least
Sent from my SPH-M930BST using Tapatalk 2
my setup running ct mod
Has Anyone Else Had Issues With using UOT W/ The New Megatron?I Always Get SHTF When Using It....I used The Stock Theme Mod Files For File upload.
So Heres A Copy Of The SHTF Log I Just Got In The Same Process.Can Anyone Tell Me If Its The Files Im using or is it the websites toolkit?
Error log: UOT-01-05-01-38-1-SHTF.txt
Decompiling framework-res.apk UOT-01-05-01-38-1
I: Loading resource table...
I: Loaded.
I: Decoding AndroidManifest.xml with resources...
I: Decoding file-resources...
I: Decoding values */* XMLs...
I: Done.
I: Copying assets and libs...
Decompiling SystemUI.apk UOT-01-05-01-38-1
I: Framework installed to: /root/apktool/framework/1.apk
I: Baksmaling...
I: Loaded.
I: Loading resource table from file: /root/apktool/framework/1.apk
I: Loaded.
I: Done.
Compiling framework-res.apk UOT-01-05-01-38-1
W: Could not find sources
I: Building resources...
aapt: /lib/libz.so.1: no version information available (required by aapt)
aapt: warning: string 'lockscreen_network_locked_message' has no default translation in /home/uotftp/port5/data/working_dir/UOT-01-05-01-38-1/fw_dec/res; found: es es_US
I: Building apk file...
Compiling SystemUI.apk UOT-01-05-01-38-1
I: Framework installed to: /home/uotftp/apktool/framework/1.apk
I: Smaling...
Exception in thread "main" brut.androlib.AndrolibException: brut.common.BrutException: could not exec command: [aapt, p, --min-sdk-version, 10, --target-sdk-version, 10, -F, /tmp/APKTOOL2350126346649851286.tmp, -I, /home/uotftp/apktool/framework/1.apk, -S, /home/uotftp/port5/data/working_dir/UOT-01-05-01-38-1/su_dec/res, -M, /home/uotftp/port5/data/working_dir/UOT-01-05-01-38-1/su_dec/AndroidManifest.xml]
at brut.androlib.res.AndrolibResources.aaptPackage(AndrolibResources.java:255)
at brut.androlib.Androlib.buildResourcesFull(Androlib.java:324)
at brut.androlib.Androlib.buildResources(Androlib.java:269)
at brut.androlib.Androlib.build(Androlib.java:192)
at brut.androlib.Androlib.build(Androlib.java:174)
at brut.apktool.Main.cmdBuild(Main.java:188)
at brut.apktool.Main.main(Main.java:70)
Caused by: brut.common.BrutException: could not exec command: [aapt, p, --min-sdk-version, 10, --target-sdk-version, 10, -F, /tmp/APKTOOL2350126346649851286.tmp, -I, /home/uotftp/apktool/framework/1.apk, -S, /home/uotftp/port5/data/working_dir/UOT-01-05-01-38-1/su_dec/res, -M, /home/uotftp/port5/data/working_dir/UOT-01-05-01-38-1/su_dec/AndroidManifest.xml]
at brut.util.OS.exec(OS.java:83)
at brut.androlib.res.AndrolibResources.aaptPackage(AndrolibResources.java:253)
... 6 more
/home/uotftp/port5/data/working_dir/UOT-01-05-01-38-1/su_dec/res/values/arrays.xml:3: error: Found tag reference-array where item is expected
/home/uotftp/port5/data/working_dir/UOT-01-05-01-38-1/su_dec/res/values/public.xml:317: error: Public symbol array/shutdown_reboot_actions declared here is not defined.
/home/uotftp/port5/data/working_dir/UOT-01-05-01-38-1/su_dec/res/values/public.xml:316: error: Public symbol array/shutdown_reboot_options declared here is not defined.
Nice. :) The dialer's a little hard to read, but not impossible (unlike white text on my Halloween theme's system background :p).
