marefin
So I was attempting to flash back to stock with Odin (I was using Assonance 5.2). I turned the phone off, then while holding the volume buttons plugged in the USB like normal. Then Odin said added the phone, then I hit start. And it seemed like it was working just fine, then all of a sudden the screen on the phone turned red. Then the status bar on Odin stopped moving completely (stayed for awhile). So I think I made the next big mistake of just disconnecting the USB and taking out the battery. So now the phone won't turn on. So I'm not sure I hard bricked the phone or what? Anyone have any idea? Thanks!
edit. I've plugged the phone into the outlet charger, still nothing happens.
