scroll sensitivity
ekang
Member
Sorry if this has been posted about but I did a search and came up with nothin.
After the froyo update did anyone notice the screen scrolling sensitivity change and become less sensitive. And if you did notice a difference, which do you prefer. Thanks
I agree. It is less sensitive and I do not like it. When I was on the apps screen, it didn't want to scroll down very easy. I will try the turning off the phone trick to see if that work. I like 2.2 but that is a negative to me.
