Hi
I have searched for a solution to this but have not found an answer, and i dont know if it is a hardware or a software fault. Basically when scrolling with my Desire HD it will randomly scroll down rapidly to the bottom in like half a second, way, way quicker than you could if you tried. It does this mostly in the internet browser and very occasionally in other apps, GoSMS/menu etc. i can't honestly say if it started after the 2.2 update so can't pin it down to that but it is very annoying.
I try scrolling at a diagonal as opposed to up and down when i can and this seems to help but i want to sort it out.
Anyone know where to start in figuring out which is at fault?
As I don't do any serious typing I'm not that affected by it. I haven't a clue what functions are in place that might have influence on this, but maybe a factory reset might help you, at least it sounds better than sending the unit back for "repair".
