C cagey77 Newbie Jul 19, 2010 #1 I saved a picture from a text message I got to the SD card and can't seem to locate the pic. Any idea how i can find it?
M mazz0310 Android Enthusiast Jul 19, 2010 #2 In the download folder I think if you used the stock android messaging, handcent folder if you used handcent.
yawdapaah Android Expert Jul 19, 2010 #4 The "Files" browser views the SD card directories. If you open "Files" you should see a folder called "downloads." The picture should be in there.
