SD card accidentally removed
nabia
I need help. I use HTC explorer A310e. I accidentally Erased my SD card via settings panel and turned off my mobile. When i switched it on a white screen appeared only with HTC written on it. I removed the battery and then inserted it again and tried to do factory reset but nothing is working and only white screen is appeared. Please help me what to do. :(
Hi nabia and welcome to AF. I moved your thread here where the friendly members know your phone best. I hope they will come to your rescue. Thanks for joining and using these forums.
Referring to nibia,u gotta wait a while for the sd card to restore,takes time .Hope you understand
Sd card if more then 4gb in HTC ,it will be very very slow to install back ,less is better .this is my advice
