So i ended up rooting using my PNY 2gif card. Is there any files on this sd card that I need, or can I just swap back my stock VZW one without loosing root. Loving the WiFi Teathering!!!
I would keep it though, in case you need to get back into adb recovery. I was about to return mine the day after I bought it, but for stuff like wireless-n and if you need to reset and re-root, you'll need it.
