Hi
I've got a problem with my S2. I'm not able to put apps on to my SD card. My 16gb USB Storage is nearly full and everytime I move apps to SD card it move to the USB storage. Anyone know how to move Apps and App Data onto my SD card while also being able to use the apps?
How do you know the move to sd is not working? You have to use PC to view the files. It should be found in Android_secure. Its a hidden folder where files can only be viewed through PC. Move to sd option can be found in settings/manage applications on sd tab. You should still be able to use the apps.
