Help SD card/Apps muti question
Wolvie66
What is the biggest SD card the Samsung Galaxy S4 can take.
And how can you put apps on SD card and is that the right thing to do, or will the App not run?
Thanks in advance
Wolvie
64GB.
There is plenty of internal memory for apps. Just put all photos, music and documents on the external card.
hey do you mind helping me out? so i recieved my S4 today and i realized that the button to lower the volume seems to be more pushed in then the button to make the volume higher, may i know if this this normal? thanks
My volume rocker is even in both directions. If yours works ok I wouldn't worry about it. But if it bothers you, send it back. Life is too short to live with something you aren't happy with.
