SD card backup
What is the easiest way to back up my SD card? I fear I need to get a new one. I am not sure if it's something on my card, or the card itself. Something is causing all kinds of problems on my phone. I have done a master reset multiple times, received a replacement phone and still nothing. I have a Droid x with a 16gig card.
Personally I have a bash setup to backup all my sdcard info onto my computer. I use 7zip and just update the zip file. Works very well. You can also just drag and drop
you can check the SDCARD in windows by going into a dos box and type:
chkdsk x: /f /r
replace x with the actual drive letter (also do this from a card reader and not the phone.)
If there are any errors on the card this should repair them or at least let you know if your card is damaged
