SD card deleted?
i updated to 4.3 on 12/20 and since than i have had SD card issues..it kept saying that it has been removed from device when i have not touched it ,and yesterday the SD card was deleted...all 118 pictures on it GONE...now the phone wont reconize the card at all...HELP
Have you tried unmounting the SD Card in storage options, then switching your phone off, removing your SD card then re-inserting then switching the phone back on?
thank you for responding...yes i have done that..and nothing..after i turned the phone off and removed the SD card...when i turned the phone back on..it doesnt even reconize that there is a SD card in the slot...do you think its fried? its about 6 months old the card
The reason I mentioned what I did, my wife's Note 2 lost all media on her SD card yesterday and couldn't save anything to it, so I did what I said in my post and phew, saved.
Other than this I don't know what the issue could be, try the card in another phone first to rule your Note 2 out?
My wife's s3 did the same thing after 4.3 update. I tried all the above tasks to restore her sd card.
The s3 is now outta memory. In some weird twist, everything on the sd card was moved to the device. It's now maxed out on storage. It consonantly updates and batt life is shot. Sprint was no help,,,other than to tell us we can Upgrade her phone and even lease a new phone.
Don't know if your SD card was a Sandisk, but Sandisk SD card issue seems to be an issue with many of the Samsung devices, it had happened to me also a while ago with a Sandisk 32 GB card, lost everything on the card, and had to use a software program to get 80% of my data back, if you research there are a bunch of freeware apps to try to get your info back, at least most of it. I have since put in an 8GB card and have not had an issue since. I have not reinstalled the 32GB as I read in a few forums that Samsung doesn't like larger capacity cards sometimes, depends on the phone.
It can tell you this, my 32 GB was a legit card purchased from Costco and works just fine in the old HTC Evo, so it was not the card.
Here is a thread with some info also,
SGN2 making SD-cards corrupt!
Sd card not working
Firmware Updates Toast mSD card?
Good luck and keep us posted.
yes it is a SCAN DISK card..i just ordered a new one,i think this one is fried,i tried putting it in another phone ( also a note 2) and it didnt read it either..im so mad,i lost over 100 pictures
I had real issues with a 32GB and a 64GB SanDisk card in my S4. I ended up buying a Samsung 64GB card and have had zero issues since. All of my problems were with the card unmounting itself. I never lost any data.
i had a S3 before the note 2 and i never had any issues..i keep wondering if the 4.3 update had anything to do with this..that is when the issues started
I have a Sandisk 32GB card in my Note 10.1 running 4.1.2. As of a few days ago, the card started going berserk and kept mounting/unmounting. Wasn't going to take a chance on the card crapping out and did another full backup of it on my PC and NAS. Then transferred all files to the spare Samsung 32GB card I have.
