Help SD card failed
buggerritt
Member
I just pulled my phone from my pocket and it was frozen so I pulled battery and restarted it. The SD card format was unrecognized. I stuck it in a card reader and it wouldn't show up on my pc. I stuck a different card in my phone and it is fine. I called Sprint and the card is not covered by warranty. The warranties are device specific and Samsung does not feel that they need to cover them. I was lucky that the Sprint store did replace my card with a Sandisk card. I have numerous Microsd cards. They all came with a lifetime warranty. Samsung fails on this note. I still love this phone, though. :)
I did something simialar to this.. I pulled off the cover from the side,to take my battery out, and didn't realize that I accidentally pulled the SD card out just enough so it didn't completely fall out. then i started my phone, some of my widgets didn't appear on my screen.. opened the back cover to see SD card was just out of place.. I should have turned off the phone, but instead just reseated the SD card
Then it went corrupt.. lost all my music and apps. Doh! be careful.
