Help SD Card Failure?...
rjj130
Member
Ugh... I think my SD card is shot.
I cannot get it to mount at all in my Incredible.
It goes from 'Blank SD card - SD card blank or has unsupported filesystem.' and if I try to format it, it goes mount it, then comes up and says 'Preparing SD card', then says 'SD card safe for removal', back to the blank SD card message.
Here's the kicker... I haven't backed it up in a while and yeah, my stock recovery is on there along with some photos. Those are the only two things I care about, mainly the recovery. The photos I can learn to live without.
Any thoughts on getting it to mount so I can get it formatted and possibly extract some data from it with TestDisk?
Thanks in advance.
BTW, using Cyanogenmod 6.1.0 for the Incredible at the moment.
