SD Card, few questions
joe3428
Dear all,
newbies question:
1. My desire comes with 4gb micro SD card, however, it has already filled with unknown file for about 2gb. what are those? can I delete it?
2. If I want to change my sd card to a higher memory, can I just copy everything i have on my sd card to the new one?
fyi, I haven't rooted my phone yet.. try as hell to avoid the temptation..
many thanks in advance
regards,
Some stuff like htc sync and a manual come on the SD I believe.
Yes, you can copy over to PC then copy back onto new card. make sure your PC is set to show hidden files though
