droid newb
I'm in a world of hurt and hoping someone has a solution for me!
I took my SD Card out of my phone & plugged it into my laptop. I then took all the files from my SD card and dragged them into a folder. Next I deleted those files from the SD card so I could use it for another purpose.
After I finished this process I got rid of what I had put on the SD card for the other purpose & dragged all the Android files from that temp folder back to my SD card.
Now my phone won't recognize my SD card. The card will not mount and when I boot my phone I get a message that says "blank SD card". When I click on that message it prompts me to reformat my SD card and warns me that everything on it will be lost.
So what I'm wondering is: can I reformat the card, plug it back into my laptop, drag the files back to the SD card and all will be well?
Or is there something else I need to do?
Or am I screwed?
I even tried a CWM restore...but the restore is on the SD card so that obviously isn't an option.
At any rate, I really need some help here and I'm hoping someone can provide some guidance and direction for me.
Thanks!
Or am I screwed?
Thanks!
