Root SD card help
jpr8
Member
Looking for a little help/explanation on partitioning SD card.
I have root and recovery (RA-OptimusM-2.2.1-GN).
I want to solve the internal memory problem and try to install a new rom eventually.
I have read posts that say I should partition AND I've read posts that say remove partitions.
Not sure if I should only partition with certain roms or if it is ok no matter which rom I install.
I currently have the stock (2GB) SD card in. Seen somewhere that a should have a class 4 SD and somewhere else said a class 6 SD. I didn't know there were different classes of SD cards...so can I just use the stock one for now or do I need to buy a new card first?
Not sure if doing a nand backup is what I need to do or do I copy contents of my sd card to my computer...is this the same thing? (for the record I have done both)
Do I need to remove apps that I'm currently using to save memory? ("App2SD" coupled with "Move2SD Enabler"). Is this app from the market the same as using the Darktremor App2SD?
There is a lot of info here which I appreciate, but a lot of it is several months old so I'm not sure what is the best(most up to date) procedure. For example I was about to try rooting my phone after reading older posts only to come across the Gingerbreak method that made it much simpler.
Thanks for any help/answers. Just want you to know I did search and read many posts but as you can see it still left me with many questions.
I can tell you that i have flashed 4 maybe 5 different roms without partitioning sd card. Also im using stock 2gb card. And nand backup should suffice any needs for restoring if you oops your phone up, as ive done and had to start over. So basically if your rooted and using recovery then your next step is to choose a rom and start flashing. Good luck to you,
im running reppards cm7 rom, i have a 4gb sd card partitioned with a 1gb ext partition and am using darktrems a2sd beta 4 with an ext3 partition. have also moved the dalvik-cache to the sd, i currently have close to 100 apps installed, am using about 60% of my ext partition, and have had exactly 0 errors with this setup, my phone is also as fast as one could ask for, ie, there is no lag doing anything, i touch something and it is there. if you are interested in setting any of that up, i have no problem helpin ya, but either way its up to you, the phone doesnt have a whole lot of "app" memory without a2sd.
I wouldn't mind a guide for this tripdoc. I have been avoiding it with my 16gb SD card because I'm not sure if a2sd will work with the card. Also I'm not exactly sure how to use scripts like a2sd scripts. Or even where to obtain such scripts.
But 16gb of app space? Yesplease!
Ok so I've partitioned my 8gb SD card to ext4. My issue is I can't figure out how to unpartition it (on the device) to fat32. Any help?
lol.. i dont recommend using more than 1gb honestly, some have gone higher and been fine.. but the larger the ext partition the more likely your are to experience a failure from everything i ahve read. some say that with ext4 you can go as high as 2gb.. but honestly.. im using 60% of mine and have more apps than i even use.. amazon market is great for the free app fo the day lol. but anyway here its goes for ya.
1: make a backup of everything on your sd card. copy it all to your computer. when partitioning your sd card you will lose everything. while your at it make a nandroid backup incase anything goes wrong, and copy that to your computer as well lol
2: boot into recovery, go to the partition sd card menu. select partition sd. for swap set to 0 and for ext set to 1024. once it has completed partitioning go back to the partition sd menu and select SD:ext2 to ext3
3: download this. [Script][A2SD] Darktremor 2.7.5.3 Beta 04 [N1] (01/29/2011) - xda-developers then from ain menu in recovery select USB-MS Toggle to turn on usb file transfer. copy the script to your sd card. then disable USB-MS.
4: go to wipe menu and wipe the /cache partition and then wipe the Dalvik-Cache.
5: go to the flash zip menu and select the darktrem a2sd beta4 script and flash it. once complete you can reboot your phone, be patient as your phone will be rebuilding your dalvik-cache and may take a alittle longer than usual to boot up.
6: open terminal emulator if at the $ prompt, type su and hit enter to get to # prompt. type a2sd zipalign and hit enter yourt phone might reboot, cant remember, if it does reboot go back into terminal and go back to # prompt and then type a2sd cachesdreset and hit enter. this will reboot your phone and it will take a few minutes to boot back up, it is moving the dalvik-cache to the sd card and rebuilding it.
now your done, copy your files back to your sd card and thats it.
if you go to Settings > Storage on your phone, and format the sd card it will erase the ext patition, just make sure you backup your files
PHP:
PHP:
Followed to the letter and works like a charm. Thanks
ok guys so this is going to be my first time posting on herre too but let me tell youm since i seen this website, i managed to root my phone install cm 7 clock workmod and have my phone fully functional,, im pretty good with gadgets off the top byt i came to a problem. because i got a new se=d card, the i tried to get my sd card to partition i partitioned but i dont know how to be able to choose certain partitions on my sd cards, i messed up when i think i partitoned the fresh part of the sd card instead of the original. long story short i need some sort of program that would in some way let me choose certain partitions on my sd cards and im guessing its called "flashing" i dont really understand what flashing is but i know that ive gotten this far without asking anyone for help on my phone but now i just want to use my 8 gig card store all the downloaded apps that i can manage to bunch up on my laptop, and back up all important data from the cards and such, but i just need someone to explain to me how to do this and how to make sure i dont brick my phone because i have not done so thus far... would appreciate any advice
i am totally up for doing my phone up to optimal condition. when i got the phone i got it activated, it took me three days to learn about cm7 androids in general. In one evening, and a morning . i had rooted my phone via flash image gui ttitanium backup, clockworkmod, i downloaded app2sd all my favorite apps and stuff.. u just need to boot back into that batch of information on my sd card.. someone please help
Thanks for confirming it for me.
Does this work with Jonidey's stock 2.2.1 recovery? I've heard that it has no problem making ext3 partitions, but has problems formatting ext3 partitions. Should I switch up to GNM Recovery?
Also, should I re ROM back to a stock ROM before attempting this? I have a LOT of apps already moved to the SD card right through AppManagement in Android. I have this feeling that if I don't start fresh, its going to cause me a migrane later today.
(Edit)
I bit the bullet and just decided to re ROM Reppards CM7.1 ROM. Everything I have is backed up, so no worrys lol. Once I'm back to a fresh ROM, I'll do a2sd and reinstall all of my apps.
Also, should I re ROM back to a stock ROM before attempting this? I have a LOT of apps already moved to the SD card right through AppManagement in Android. I have this feeling that if I don't start fresh, its going to causIlle me a migrane later today.
Jonideys is the recovery i have and everything worked smoothly off a fresh rom flash, then went thru the steps shown. As to if jonideys problem with formating ext3 partitions idk, but i do know my phone is only using about 7% capacity with 20 or so apps on sd card also i have stock 2gb sd card with 1gb partition, phone itself is more responsive and no lag at all with bobz latest rom. Also its showing 201mbs internal and it has 192mbs remaining to be used. All in all im grateful and would recomend with or without the migrains.
Well, after putting Reppards CM7.1 ROM back on my phone and making it like new, I installed a2sd. Went off without a hitch. Phone is telling me I'm using 3.7Mb of space, with 197Mb left. Phone feels snappier.
Dont trust Titanium Backup to put backed up apps on SD card, so I'm going to reinstall all my apps the old fashoned way. Good thing I always have a backup of my original purchased APKs.
And thanks again tripdoc, for instructions. Your the best. Thanks misleadb4 for testing and confirming this works before a newb bricks his phone.
Ok so I had my apps on my 8 gig sd along with music. I moved all my apps tothis sd card and titanium nack up nthe I tried to partition my bd card through recovery. So I think I have two parttions on my sd card. My problem is I think created a partition on my phone ext4 with 2 gigs when I rebooted it mounts the new paftition. I need to be able to mount the good half of my sd card and try again. All my apps are on the data is on the good half of the partition can someone explain how to mount a seperate partition on the same sdcardsbefore I brick my phone. I have a feeling that I'm gonna brick my phone if I keep going without anyones advice please help me guys I'm no newb to tech gadgets and barely got thisphone and I already have root acces fully funtional cm7 bobsversion I just need some tech help
