Help SD Card help
spencer320
Hey All.... I need some help plz.... I just replace my water damaged phone with a new one and Im trying to access all the old apps I downloaded and moved to the SD card. I went into the Manage Apps from the home screen but it tells me there's no apps on the SD card, but it shows I used 757mb and still have 1.1 GB free. I bought this phone from an Ebay dealer and no SD card was included and I don't remember what originally was on the Card...
Any ideas or am I screwed?
All my old pic, video and documents are on there and now on my phone, just no games, etc or data for those games.... at least not that I can find!
Thats because the actual apps wo t be transfered to the card only the data from them you have to go thru data files to find what games you had aand reinstall then your old data from the sd should load
Yeah. It won't help now, but what you should have done is actually backed up the apps with Astro (or similar), instead of just moving them. Next time.
If you got your apps through Google play, you can re download when you sign in
Thanks for the help so far.... is there anything I need to do to get the game progress back or should it be automatic?
Some games like angry birds don't restore from sd, most apps store their info on the phone so unless you used titanium or another program to backup you are out of luck for most programs
my warp has no sc card and i recently rooted my warp and now it goes to a screen with the android guy when i turn on my phone and i cant navigate away to any other screen....any clues on what i did to make my phone go to this screen and what i can do to fix it.....anything even back to factory???? and i need my phone asap cause its my work phone...plzplz
what method did you try to root it with? are you on boost mobile or public mobile? you don't have the new warp sequent do you?
if you turn the phone off or pull the battery, then turn the phone back on while holding the volume down and power button together, do you get a recovery screen? is the recovery screen text blue at the top or white?
